One solution to: "avrdude: initialization failed, rc=-1"
by extremis on Fri Oct 09, 2009 2:29 pm
This took me a while to figure out, but I hope it helps others. When using avrdude to burn the atmega168v, you may encounter an error like:
$ avrdude -c usbtiny -p atmega168
         this check.
After much reading, I determined I needed to 'guess' at the -B (bitclock) values. So, I modified the Makefile in the firmware download, and I was able to perform all portions of the 'make full.' I'm still trying to determine the actual significance of these values, but this works for me consistently (YMMV.)
full: $(TARGET).hex $(TARGET).eep
   $(AVRDUDE) $(AVRDUDE_FLAGS) -B 25 -u -U lfuse:w:0xE2:m -u -U hfuse:w:0xc6:m
   $(AVRDUDE) $(AVRDUDE_FLAGS) -B 25 -U flash:w:$<
   $(AVRDUDE) $(AVRDUDE_FLAGS) -B 35 -U eeprom:w:iveep.hex
burn-fuse:
reset:
extremis
