Awhile back I made the Trinket Analog Meter clock, loved it! Anyway I'm trying to make another one with a Boarduino (328P) that I got laying around. I'm confused about which pins on the Boarduino to use for PWM. I look at the Atmega 328 pinout and compare to the Trinket thinking I can just replace pin numbers in the sketch but it's not as smooth a process as I first thought. Apart from PWM the pins all serve other various functions.
Thank you
Jerry
PWM pins
Re: PWM pins
PWN capable pins on the Boarduino are the same as for an UNO. Pins 3, 5, 6, 9, 10 & 11.
- janowatzki
Re: PWM pins
Thanks for the quick responce, didnt expect that on a weekend! I went throught the original sketch and changet the hours (pin 1) to pin 3 and minute (pin 4) to pin 5. heres the error when I compile:
Is this a side effect of not using the Trinket?Arduino: 1.8.5 (Linux), Board: "Arduino Duemilanove or Diecimila, ATmega328P"
/home/jerry/Arduino/Nano_analog_clock/Boarduino_analog_clock.ino/Boarduino_analog_clock.ino.ino: In function 'void PWM5_init()':
Boarduino_analog_clock.ino:80: error: 'TCCR1' was not declared in this scope
TCCR1 = _BV (CS10); // no prescaler
In file included from /home/jerry/arduino-1.8.5/hardware/tools/avr/avr/include/avr/io.h:99:0,
from /home/jerry/arduino-1.8.5/hardware/tools/avr/avr/include/avr/pgmspace.h:90,
from /home/jerry/arduino-1.8.5/hardware/arduino/avr/cores/arduino/Arduino.h:28,
from sketch/Boarduino_analog_clock.ino.ino.cpp:1:
Boarduino_analog_clock.ino:81: error: 'PWM1B' was not declared in this scope
GTCCR = _BV (COM1B1) | _BV (PWM1B); // clear OC1B on compare
Boarduino_analog_clock.ino:83: error: 'OCR1C' was not declared in this scope
OCR1C = 255; // frequency
exit status 1
Re: PWM pins
Yes. The timers - and associated timer registers on the Atmega-328P are different from the ones on the ATTiny85.Is this a side effect of not using the Trinket?
Arduino timers are an advanced topic, but there are a few good tutorials out there:
http://sphinx.mythic-beasts.com/~markt/ ... imers.html
https://arduino-info.wikispaces.com/Timers-Arduino
https://oscarliang.com/arduino-timer-an ... -tutorial/
