PCF8523 Real Time Clock Not Updating and "if statement" prob
by KylePo on Tue Dec 18, 2018 9:30 pm
Hey Everybody,
So I recently bought a PCF Real time clock module for my Arduino nano. The intended purpose is to cause an action to happen two times a day. I have two problems. My code is pasted below. One is that when I look in the serial monitor, the time will constantly reset itself every time I close and reopen it. I just want to make sure that when the device is autonomous it will actually count the time. The second thing I need help with is the if-statement in the void loop. It does not work, and I never see the then-statement in my code. Is there a problem with how I am using the now function? Thanks!
#include <Wire.h>
#include "RTClib.h"
RTC_PCF8523 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
int timer = 0;
int GREEN_LED = 12;
int RED_LED = 11;
int BUTTON = 4;
  while (!Serial) {
    delay(1);  // for Leonardo/Micro/Zero
  Serial.begin(57600);
  if (! rtc.begin()){
    Serial.println("Couldn't find RTC");
    while(1);
  if (! rtc.initialized()) {
    Serial.println("RTC is NOT currently running");
  rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
  DateTime now = rtc.now();
  /*Serial.print(now.year(), DEC);
  Serial.print('/');
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.day(), DEC);
  Serial.print(" (");
  Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
  Serial.print(") ");*/
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  Serial.println();
  if ((now.minute(), DEC) == 1) {
    Serial.println("Yay!"); //not working
  delay(3000);
KylePo
Re: PCF8523 Real Time Clock Not Updating and "if statement"
by adafruit_support_bill on Tue Dec 18, 2018 9:50 pm
This line in your setup is resetting the time whenever setup runs:
You only want to do that if the clock is not running already.
Not sure what you are trying to test in this line:
It is not clear what the expression "(now.minute(), DEC) " will evaluate to. But it probably isn't '1'.
by KylePo on Tue Dec 18, 2018 10:21 pm
Thank you! How do I prevent it from constantly resetting while still setting it to the time I want? And where can I find information on how to turn the time into a variable?
KylePo
by adafruit_support_bill on Wed Dec 19, 2018 6:57 am
Only call rtc.adjust if the clock is not already initialized. See the example code from the library.
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    // rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
Not sure I understand your question. You already have a 'now' variable defined in your loop():
