Monochron Updating Issue
by shyam131 on Sun Jan 06, 2019 3:05 pm
I cannot get my Monochron to update. avrdude will not initialize. When running the following command:
avrdude -c arduino -p m328p -P -b 57600
I receive the following error:
avrdude: ser_open(): can't open device "-b": No such file or directory
ioctl("TIOCMGET"): Inappropriate ioctl for device
Any suggestions on who to resolve this error. I have followed all the instructions on this page: https://learn.adafruit.com/monochron/updating
shyam131
Re: Monochron Updating Issue
by toinec on Fri Jan 11, 2019 6:12 pm
Hi there,
When using avrdude, the -P argument must be followed by the port name of the device that connects to your Monochron..
Since in your example the next argument is -b, avrdude assumes that -b is the port name, which apparently fails to work :-).
Example for Linux:
avrdude -c arduino -p m328p -P /dev/ttyUSB0 -b 57600
Example for Windows:
avrdude -c arduino -p m328p -P COM3 -b 57600
Depending on the interface device connected to your Monochron, OS and avr toolchain, the values for -P and -b may differ.
The commands above work nicely for me using FTDI-Friend v1.1 in combination with Debian Linux 8 and 9 (it's been quite some time since I did avr stuff on Windows), using the Emuchron firmware.
Cheers, good luck & enjoy your clocks!
Toine
toinec
by adafruit_support_carter on Thu Jan 17, 2019 3:01 pm
It looks like there's some weird formatting error on the guide page that's blanking out that information. Scroll down a bit and see the screen shots that show the port actually being specified (COM30 in the example).
