๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Trinket - Neopixel 60 ring wall clock
by gadea on Fri Jan 11, 2019 12:51 pm
Hello; I have built this project but I noticed the clock is slow by 28 minutes.
1) Where does the RTC grab the "now" time from? the computer?
2)I read elswhere in the forums that USB 3 could be a problem, could that be the cause of this issue?
3) If I modify this code:
byte secondval = theTime.second();  // get seconds
byte minuteval = theTime.minute();  // get minutes
int hourval = theTime.hour();   // get hours
to
byte minuteval = theTime.minute() -28;  // get minutes
I will end up having negative values, is there anywhere else I can do a "minus 28 minutes" to workaround this issue?
gadea
Re: Trinket - Neopixel 60 ring wall clock
by franklin97355 on Fri Jan 11, 2019 4:35 pm
rtc.now comes from the RTC. The RTC is set with the line
 rtc.adjust(DateTime(__DATE__, __TIME__));
Which sets the RTC to the time the program was compiled. The way I handle this is to create a separate program that runs this line only and run it once to set or reset the RTC. Remove this line from your code so it won't reset the RTC every time you restart the program.
franklin97355
