~ monochrone, will you eventually play PONG?
by whiskey on Sun Feb 21, 2010 7:44 pm
in the description it says "Plenty of space for mods, a prototyping area for soldering stuff in".
So I take it it's possible that we'll see somebody mod it so we can play?
whiskey
Re: ~ monochrone, will you eventually play PONG?
by adafruit on Sun Feb 21, 2010 8:28 pm
whiskey wrote:in the description it says "Plenty of space for mods, a prototyping area for soldering stuff in". So I take it it's possible that we'll see somebody mod it so we can play?
it's open source, and "anything is possible" -- but it's not a future-telling device (yet) - so we're not sure what people will do - and that's the exciting part :)
by len17 on Sun Feb 21, 2010 8:47 pm
I've been thinking about it, but I'm not sure I want to add a pair of knobs to my clock.
adafruit wrote:but it's not a future-telling device (yet)
Sure it is! Your Monochron is telling you what time it will be in Chicago one hour from now. :)
len17
by whiskey on Sun Feb 21, 2010 10:19 pm
try it out Len!
if your looking for a clean install you can always just solder male headers then use female connectors. It would be be like a real controller! you can even mount the potentiometer (or buttons?) inside of a mini altoids tin. :)
whiskey
by ghostfish on Sat Feb 27, 2010 1:06 am
I had an idea for adding controls to play pong. According to the design page, you can get 2 digital pins free on the ATMega as well as add things to the I2C bus. Wii Nunchucks use I2C and have a joystick. Simple. My clock is currently in the mail so I can't get started on it yet though. :(
ghostfish
by adafruit on Sat Feb 27, 2010 11:24 am
We suggest just using i2c instead of trying to wrangle more pins. You can solder wires to the i2c connections (they're broken out) and then feed the wires out the back to a 'nunchuk connector' (ThingM has a couple)
by adafruit_support on Mon Mar 01, 2010 2:54 am
As for current draw, a Classic Controller, also readable with the Nunchuck connector, draws between 1.5 and 6ma of current, at 5V depending on how many buttons are pressed simultaneously. (It is hightly unlikely that ALL of them will be pressed at once.)
At least, you won't have to deal with the SDA/SCL resistors, as these have already been put on the board.
adafruit_support
Site Admin
