word clock faceplate
by rmcox on Mon Mar 04, 2019 7:29 pm
Where can I get the vinyl faceplate for the word clock?
rmcox
Re: word clock faceplate
by adafruit_support_bill on Tue Mar 05, 2019 6:49 am
The vector files for laser cutting are in the github repository for the project: https://github.com/andydoro/WordClock-N ... _enclosure
by rmcox on Tue Mar 05, 2019 3:53 pm
I am having trouble finding a vinyl sign place which will do this. Can you tell me who you have used, and where I can send the file?
rmcox
by adafruit_support_bill on Tue Mar 05, 2019 4:12 pm
We use our in-house laser-cutter. There are several on-line laser-cutting services like Ponoko.
https://www.ponoko.com/laser-cutting
You might also check for any nearby maker-spaces that may have a laser-cutter.
by rmcox on Mon Mar 25, 2019 3:46 pm
I cannot figure out how to extract the .svg file for the faceplate onto my computer so that I can take it to my local sign maker.
rmcox
by adafruit_support_bill on Mon Mar 25, 2019 4:12 pm
Use the green button on the upper right to download the files to your computer:
https://github.com/andydoro/WordClock-NeoMatrix8x8
by rmcox on Wed Mar 27, 2019 7:45 pm
So I contacted 3 local sign businesses, and actually visited 2 of them, with the .svg file for the faceplate.
They all said that the part was too small for them to cut from vinyl, and they can't laser cut vinyl, either.
I really want to make this, but I am stuck.
rmcox
by adafruit_support_bill on Wed Mar 27, 2019 7:55 pm
The faceplate for the prototype clock in the guide was laser-cut from black acrylic sheet. Most any laser-cutter should be able to handle this:
by rmcox on Wed Mar 27, 2019 8:19 pm
How thick is that acrylic?
I have a friend with a laser cutter, just have to find the material.
Thanks for all your help.
I plan to use a PIC for the electronics.
rmcox
by adafruit_support_bill on Thu Mar 28, 2019 5:51 am
The design will work with various thicknesses. It looks lie the original prototype was done with 1/8" (0.125")
Stock thicknesses vary quite a bit from different suppliers. But anything in the 0.100" to 0.175" range should work fine.
by rmcox on Thu Mar 28, 2019 11:17 am
Thanks again. I ordered some 1/8" material.
rmcox
