Adafruit Feather M0 Adalogger
by Herrx on Wed Apr 03, 2019 4:35 am
Hello guys!
I'm looking for a datalogger and I found the "Adafruit Feather M0 Adalogger" there is a microcontroller and a SD-Card Slot on board.
What I want to know is, is it possible to include a time stamp by the datalogs like it is possible with an RTC? I saw the board with the SD-Slot and the RTC-Battery but there is no microcontroller on board. I can connect an Li-Battery as a powersupply to the "Adafruit Feather M0 Adalogger" but works it like the RTC battery?
Thanks in Advance.
Herrx
Re: Adafruit Feather M0 Adalogger
by adafruit_support_bill on Wed Apr 03, 2019 6:07 am
The Feather Adalogger boards do not have a built-in RTC. We do have RTC wings.
https://www.adafruit.com/product/3028
https://www.adafruit.com/product/2922
There are also WiFi and GPS options for a reference time-base.
by Herrx on Wed Apr 03, 2019 6:22 am
Yes thanks for your hints.
I saw the the wing with the SD-Card and the RTC-Battery.
So it's not possible to use only the
https://www.adafruit.com/product/2796
and get a timestamp in my data logs? So the LI-Battery does not support ernergy like the RTC?
So I have to use one of your recommended wings when my logger is poweless sometimes and I'll want a right timestamp?
Herrx
by adafruit_support_bill on Wed Apr 03, 2019 7:25 am
You can use the processor's system clock to generate a time-stamp. But you can expect significant drift over time - probably several minutes a day at least.
You can use a LiPo to provide continuous power. But as noted above, the system clock is not nearly as precise as the time-base in a dedicated RTC.
by Herrx on Wed Apr 03, 2019 8:16 am
Ok so anyway I have to use 2 boards to realize my datalogger. How long is the lifetime of the RCT-Battery? Or how many hours/days can I bridge the the correkt time?
Herrx
by adafruit_support_bill on Wed Apr 03, 2019 8:31 am
The DS3231 RTC has a timekeeping current of about 1uA.
A CR1220 coin cell has a capacity of about 37mAh.
So the battery should allow the RTC to keep time for around 37000 hours (more than 4 years).
