ICE Tube 888888 problem
by bobster on Sun Apr 18, 2010 8:27 am
> Hi,
I think I messed up my Icetube clock's display- whenever I plug it in it displays 888888 and then the fuse goes off. The problem started with extra lights on the display. I tried to troubleshoot by touching the solder joints when it was still on to see if those areas would turn off. Do you think it's the controllers? Can I order new max chips and VFD drivers?
bobster
Re: ICE Tube 888888 problem
by adafruit on Sun Apr 18, 2010 1:31 pm
OK, first off you should never ever touch the circuit board or solder anything while its plugged in. There are some high voltages on board and you can get a shock! :(
Next up, it sounds like at least you have the boost converter working. Do you get any beeps?
by bobster on Mon Apr 19, 2010 6:34 am
There's a beep when I plug it in, the display is bright, then a beep when the fuse goes off. That was a bit dumb of me to try to see if I could get the display problem resolved while it was on. :oops:
bobster
by adafruit on Mon Apr 19, 2010 10:59 am
ok turn it off & wait a bit
remove the tube and VFD driver. what happens now to the fuse?
by bobster on Mon Apr 19, 2010 10:24 pm
I just tried taking the VFD and tube out- the fuse stays cool.
bobster
by adafruit on Tue Apr 20, 2010 10:15 am
ok now put the VFD driver OR the tube in and see which is shorting the fuse
OR test
by bobster on Thu Apr 22, 2010 12:40 am
With just the tube there was no heat.
With just the VFD driver the fuse got warm but didn't go off. The VFD chip felt hot when I left my finger on it. The Maxim stays cool.
Then I put the tube in with the VFD and it overheated. Maybe that's all pointing to the VFD chip?
bobster
Re: OR test
by adafruit on Thu Apr 22, 2010 11:22 am
bobster wrote:With just the tube there was no heat.
your report doesnt make any sense, the VFD chip is the maxim chip. how is one cool and one hot ? :(
by bobster on Thu Apr 22, 2010 8:22 pm
Sorry, did I misuse 'driver'; and 'chip'?
The ATMEGA168v gets hot. I wasn't testing the Maxim chip, but right now I gotta wait for a new tube before I can test that out again.
bobster
by adafruit on Thu Apr 22, 2010 10:17 pm
the tube doesnt seem to be the problem. something else is wrong, you can try to post a clear photo of your kit we will look for soldering errors.
by bobster on Sun May 02, 2010 12:42 am
I got another IceTube kit and assembled it without any problems. :D
I tested the two chips from the messed up one, switching one and then the other in the new clock, and they both don't work anymore. :(
I think I messed up, but it may work again if I get new chips.
Thanks for your help.
bobster
by adafruit on Sun May 02, 2010 7:08 pm
for new chips, email support@adafruit they'll help you out!
