Can't make it past the first test
by McUzi on Tue Apr 20, 2010 10:56 am
well, here goes kit #2. I double checked to see that I installed things with the proper polarity. On the first test, the power supply shows good voltage but the tests in the instructions result in no reads. (.14-.3). My meter is set on 20VDC so I am once again clueless!
McUzi
Re: Can't make it past the first test
by adafruit on Tue Apr 20, 2010 11:11 am
can you take a sharper photo of the bottom?
by McUzi on Tue Apr 20, 2010 12:33 pm
is this better?
McUzi
by adafruit on Tue Apr 20, 2010 4:44 pm
so the 5v regulator doesnt work? whats the voltage on each of the pins of the 7805?
by McUzi on Tue Apr 20, 2010 7:09 pm
.56 on the outboard first pin and 0 on the other 2 pins. I must have either installed something backwards or have a bad solder joint?
McUzi
by McUzi on Tue Apr 20, 2010 8:29 pm
oh shit.....I broke a pin off of the buzzer and ordered up some more--kit on hold now. Double checked solder points to see if I could spot anything. Nothing looks out of place. Now I will wait on more buzzers to fat-finger :?
McUzi
by adafruit on Tue Apr 20, 2010 9:46 pm
check your diodes!
by DarrenG on Wed Apr 21, 2010 4:20 am
D1 appears to be in the wrong way round.
Darren Griffin
DarrenG
