PCF8523 on Adafruit Assembled Data Logging Shield
by miaotee on Thu Sep 12, 2019 10:52 pm
Recently, I purchased an Adafruit Assembled Data Logging shield and METRO 328 for my project. And the programming for its own RTC (PCF8523) is following the guidance:
https://learn.adafruit.com/adafruit-dat ... time-clock
https://learn.adafruit.com/adafruit-pcf ... th-arduino
It works well when I upload my codes on the device, and takes the Date and Time according to the computer I am using.
However, when I disconnect it with my computer and run it using a battery, the start time is consistent with the time when I upload my code. For example, the time I upload my code to the device is 08:34:23, next time I use the device, the start time is still 08:34:23, even the exact time is 12:22:00.
Technically, the RTC should run with a coin cell even Arduino battery dies or is reprogrammed.
Could you please help me with this program?
#include "RTClib.h"
#include <Wire.h>
RTC_PCF8523 RTC;
void setup(void)
  RTC.begin();
  RTC.adjust(DateTime(F(__DATE__), F(__TIME__)));
  Wire.begin();
  if (!RTC.begin()) {
    logfile.println("RTC failed");
void loop(void)
  DateTime now;
  now = RTC.now();
  logfile.print('"');
  logfile.print(now.year(), DEC);
  logfile.print("/");
  logfile.print(now.month(), DEC);
  logfile.print("/");
  logfile.print(now.day(), DEC);
  logfile.print(" ");
  logfile.print(now.hour(), DEC);
  logfile.print(":");
  logfile.print(now.minute(), DEC);
  logfile.print(":");
  logfile.print(now.second(), DEC);
  logfile.print('"');
miaotee
Re: PCF8523 on Adafruit Assembled Data Logging Shield
by franklin97355 on Thu Sep 12, 2019 11:28 pm
You need to run this line only to set the time then remove it or comment it out in your code.
franklin97355
by miaotee on Thu Sep 12, 2019 11:39 pm
franklin97355 wrote:You need to run this line only to set the time then remove it or comment it out in your code.
Hi, Franklin
Thanks a lot for your reply.
I am still confused that once the code is uploaded and the device is disconnected with my computer, no matter how many times I run my device portablely, the start time is always constant.
Any comment from you? Thanks
Best wishes!
miaotee
by franklin97355 on Thu Sep 12, 2019 11:45 pm
As stated above remove the line of code.
franklin97355
by miaotee on Fri Sep 13, 2019 2:11 am
franklin97355 wrote:As stated above remove the line of code.
Hi, Franklin
Thanks a lot.
miaotee
