Newbie Help
Newbie Help
by kw5368 on Sat May 15, 2010 11:06 am
I am new to C and AVR programming and have decided to use the Ice Clock as a basis to help me learn both. I have started to build the clock from scratch and am at the point where I need to program the ATmega. I have built the USBTiny and it appears to be working fine through AVRDude. At this point, my biggest concern is making sure that I get the fuse bits programmed properly. I have used the AVR fuse calculator link posted on the Adafruit site and have came up with these values for the fuses since I will be using the iv.hex file downloaded from the Adafruit site to program the ATmega.
lfuse 0xE5
hfuse 0xDE
efuse 0xF9
My thoughts were that the clock uses an external crystal for timekeeping, the internal clock should not be divided internally because it is used for the boost, the brown out detection should be set to 1.8V and the other settings left at default.
If I have made a mistake in my thinking, I would appreciate any help in pointing me in the right direction too see where I made my mistake.
Thanks for any help,
Ken
kw5368
Re: Newbie Help
by adafruit on Sat May 15, 2010 5:20 pm
the fuses are in the Makefile
Re: Newbie Help
by kw5368 on Sat May 15, 2010 8:37 pm
Thanks for the reply. I now have the ATmega programmed and the clock built. All I have to do is mount it in the case. I still need to figure out where I made my mistake on the fuse settings though. That is part of the learning process.
Thanks for the help,
Ken
kw5368
