24 to 12 hour
24 to 12 hour
by LitingWolf on Sat Feb 08, 2020 8:59 pm
I have ds3231 rtc how do I change to 12 hour I know I have to change the bit but I don't know how to do that
LitingWolf
Re: 24 to 12 hour
by LitingWolf on Sat Feb 08, 2020 9:44 pm
im using the adafruit rtc3231 lib
LitingWolf
Re: 24 to 12 hour
by adafruit_support_mike on Sun Feb 09, 2020 3:58 am
The CircuitPython module for the DS3231 doesn't have a function that changes the 12/24 setting, so you'll have to add one.
The instructions from the Register module explain how to do that in general terms:
https://github.com/adafruit/Adafruit_Ci ... n_Register
Re: 24 to 12 hour
by LitingWolf on Sun Feb 09, 2020 9:07 am
Its Adafruit DS3231 Precision RTC Breakout the one i have
LitingWolf
Re: 24 to 12 hour
by adafruit_support_bill on Sun Feb 09, 2020 9:31 am
Without knowing what language you are programming in, it is hard to provide specific advice. If programming in Python, you need to use the Registers module as Mike suggests. If programming in Arduino, you can use Wire._I2C_WRITE(). The 12/24 hour mode selection bit is bit 6 of register 0.02 as detailed on page 11 of the data sheet.
https://cdn-shop.adafruit.com/product-f ... DS3231.pdf
Note that changing the mode of the chip may confuse other functions in the library that may be expecting things in 24 hour mode.
A simpler approach is to just leave the chip the default mode and handle it in your code:
something like:
if (hour > 12
    hour = hour - 12;
    PM = true;
