After five years, my Ice Tube clock stopped working. There was a "pwr rset" (power reset) message, so I unplugged the clock, plugged it back in and it would work for a day or so. I tried three different power supply cords. Same result. Then there was a "bad batt" message, so I replaced the battery. Now today, nothing that I have tried will get it to work.
Is there a component that I could replace? Is there a way to test it? If so how and what parts?
Something different happened today as unplugged it, for a split second all of the digit would flash. Weird.
Thanks for your help.
Ice Tube Clock stopped working :(
- adafruit_support_bill
Re: Ice Tube Clock stopped working :(
I'd start with the Ice Tube troubleshooting guide here: viewtopic.php?f=41&t=27032
Since it has been working OK for some time, the assembly is probably fine. You can skip to the power supply/boost converter section.
- rjhike
I haven't been able to find the problem. Is there a company or individual for hire that can repair the clock?
That is not a service that we offer. If you pot some details about what you have found in your troubleshooting efforts, we may be able to offer some advice.
- rjhike
Since there was a "pwr rset" error and "bad bat", I started by installing a new battery. I tried two different batteries. I verified that the battery voltage is good.
I also tried three different power supplies.
I have another Ice-Tube clock, so I tried the tube from the non-working clock and put it in the other clock, and the tube worked. So I know that the tube is okay.
All the solder joints are good. It was working for years.
I don't know what component to check. Is there a component that "goes bad"?
I was hoping that another reader would know someone who could get it working for me.
Components do fail over time. And marginal solder joints tend to gradually deteriorate. From the symptoms you describe, I'd suspect something in the power supply/voltage regulator part of the board. The troubleshooting guide I linked earlier has a list of things to check. viewtopic.php?f=41&t=27032
