RTC DS3231
For RTC breakouts, etc., use the Other Products from Adafruit forum
LitingWolf
RTC DS3231
Post by LitingWolf »
so I'm wondering i had a ds3231 and it stopped working idk why but it stopped detecting the rtc I got another rtc that worked then later it stopped working any idea why?
I'm thinking of making one of my own due to it would work more into my project for when i get a board it would be an rtc built in instead of having a separate one
LitingWolf
Re: RTC DS3231
i get this now on the comport
⸮f⸮`⸮⸮~~x⸮⸮`⸮ff⸮⸮⸮⸮qx
Gambalunga
Re: RTC DS3231
Post by Gambalunga »
LitingWolf wrote:i get this now on the comport
I imagine that you have something like this in your setup:
  delay(1000);
  Serial.begin(115200);
  while (!Serial);  // wait for serial port to connect. Needed for native USB
You need to make sure that the serial speed, in this case 115,200 baud (but could be different), is matched by the speed set on the serial monitor panel. You see this setting to the bottom right of the serial monitor panel.
When you need assistance it is always a good idea to specify exactly what components you are using and to quote your code that is having the problem. Use the
 button when posting and paste your code between the two code tags.
Return to “Clock Kits (discontinued)”
