so I'm wondering i had a ds3231 and it stopped working idk why but it stopped detecting the rtc I got another rtc that worked then later it stopped working any idea why?
I'm thinking of making one of my own due to it would work more into my project for when i get a board it would be an rtc built in instead of having a separate one
RTC DS3231
- LitingWolf
Re: RTC DS3231
i get this now on the comport
⸮f⸮`⸮⸮~~x⸮⸮`⸮ff⸮⸮⸮⸮qx
- Gambalunga
Re: RTC DS3231
I imagine that you have something like this in your setup:LitingWolf wrote:i get this now on the comport
delay(1000);
Serial.begin(115200);
while (!Serial); // wait for serial port to connect. Needed for native USB
When you need assistance it is always a good idea to specify exactly what components you are using and to quote your code that is having the problem. Use the
button when posting and paste your code between the two code tags.
