How to get DS1307 hour in AM/PM Format easily?
by obbi13 on Fri Dec 31, 2010 1:40 pm
Hello and Happy new year beforehand!
After getting my DS1307 working beautifully I put together a nice sketch (at least for me) to print out the temperature (from a 1-Wire DS18B20) and the date time (from Lady Ada DSRTC1307 breakout board) by toggling a switch to a serial enabled (by SparkFun serial backpack) 16x2 LCD. Everything works perfect right now, but I would like to change the time format to AM/PM instead of the 24Hrs format. I have looked at the RTClib.h and haven't found a method or functions for this. Maybe I'm not looking at the right place or something but I'm sure there should be a method or library where that should be already implemented. I have used methods/functions from many others around. Also feel free to use it as your heart desires.
Anyway, here's my code (sorry for the coding mess, it's been almost 10 years since I programmed again and it's a wip:
  Sketch to print the temperature from a DS18B20 on a 16x2 serial enabled
  LCD (SparkFun v2.5) attached to a SparkFun LCD serial backpack.  Also prints the
  date and time from an AdaFruit RTC 1307 breakout board.
#include <Wire.h>              // for easy I2C communications with the RTC
#include <OneWire.h>           // OneWire communication library
#include <DallasTemperature.h> // TEmp Sensor DS18B20 library
#include <math.h>              // library for math manipulations (might not be needed)
#include <SparkSoftLCD.h>  // library to manipulate the LCD
#include "RTClib.h"            //Real Time Clock library (by LadyAda)
#define RTC5vPin 17 // pin 17 (analog pin 3) will be used to provide +5v to the RTC
#define RTCgndPin 16 // pin 16 (analog pin 2) will be used to provide GND to the RTC
RTC_DS1307 RTC;
#define LCDtxPin 2           // Using Digital Pin 2 as the Soft Serial Tx output
#define LCD_WIDTH 16         // LCD width definition
#define TempSensor_PIN 14    // Analog Pin 0, digital 14
#define buttonPin 12         // Digital pin 12 for push button
#define LED_PIN 13           // Digital Pin 13 led
float temp;                  // temperature variable
int decimals = 1;            // Decimal precision on the temperature
int gate = 0;                // counter to preserve state on push button switch
OneWire oneWire(TempSensor_PIN);  // instantiate a OneWire object
DallasTemperature sensors(&oneWire); // instantiate a sensor (DS18B20) object(s)
long interval = 500;            // interval in ms to get temperature and print it on LCD
SparkSoftLCD LCD = SparkSoftLCD(LCDtxPin, LCD_WIDTH); // create an LCD object with soft serial on pin 2.
  pinMode(LED_PIN, OUTPUT);       //sets pin for output
  pinMode(RTC5vPin, OUTPUT);      //sets Pin for output
  digitalWrite(RTC5vPin, HIGH);   // turn pin on (5v) to power RTC
  pinMode(RTCgndPin, OUTPUT);     //sets Pin for output
  digitalWrite(RTCgndPin, LOW);   // turn pin off to (GND) to power RTC
  pinMode(buttonPin, INPUT);      //Sets pin for input
  Wire.begin();                   // Initialize I2C protocol for clock communications
  pinMode(LCDtxPin, OUTPUT);      // Set defined Pin as an Output Pin for transmission
  LCD.begin(9600);                // Set baud rate speed to the LCD backpack on the defined Pin
  LCD.clear();
  RTC.begin();
  sensors.begin();
  if (! RTC.isrunning()) {
    LCD.print("RTC is NOT running!");
//  following line sets the RTC to the date & time this sketch was compiled
    RTC.adjust(DateTime(__DATE__, __TIME__));
  } // end if for RTC adjust
void loop(){
  if(digitalRead(buttonPin)  == LOW){
     gate++;
  if(gate == 0){
    digitalWrite(LED_PIN, LOW);
    printTemp();
 //   delay(interval);
  if(gate == 1){
    digitalWrite(LED_PIN, HIGH);
    printClock();
    gate = 0;
    delay(500);
/**********************  BEGIN RTC FUNCTIONS  **************************/
void printClock(){
    DateTime now = RTC.now();
    LCD.clear();
    LCD.print("Date: ");
    LCD.print(now.month(), DEC);
    LCD.print('/');
    LCD.print(now.day(), DEC);
    LCD.print('/');
    LCD.print(now.year(), DEC);
    LCD.print("Time: ");
    LCD.print(now.hour(), DEC);
    LCD.print(':');
    LCD.print(now.minute(), DEC);
    LCD.print(':');
    LCD.print(now.second(), DEC);
/**********************  END RTC FUNCTIONS  **************************/
/*******************  BEGIN TEMPERATURE FUNCTIONS  *********************/
void printTemp(){
  float temp;
  sensors.requestTemperatures(); // Send the command to get temperatures
  LCD.cursorTo(1,1);
  LCD.print("Real Time Temp: ");
  LCD.cursorTo(2,1);
  temp = sensors.getTempCByIndex(0);
  printDouble(temp,decimals); LCD.print((char)223); LCD.print("C ,");    // display in Celsius
  temp = sensors.getTempFByIndex(0);
  printDouble(temp,decimals); LCD.print((char)223); LCD.print("F  "); // display in Fahrenheit
void printDouble(double val, byte precision) {
  // prints val with number of decimal places determine by precision
  // precision is a number from 0 to 6 indicating the desired decimal places
  // example: printDouble(3.1415, 2); // prints 3.14 (two decimal places)
  LCD.print (int(val));  //prints the int part
  if( precision > 0) {
    LCD.print("."); // print the decimal point
    unsigned long frac, mult = 1;
    byte padding = precision -1;
    while(precision--) mult *=10;
    if(val >= 0) frac = (val - int(val)) * mult; else frac = (int(val) - val) * mult;
    unsigned long frac1 = frac;
    while(frac1 /= 10) padding--;
    while(padding--) LCD.print("0");
    LCD.print(frac,DEC) ;
/**********************  END TEMPERATURE FUNCTIONS  ********************/
obbi13
Re: How to get DS1307 hour in AM/PM Format easily?
by oPossum on Fri Dec 31, 2010 6:43 pm
The easy way is to just convert the 24 hour format to 12 hour format when printing.
 // Put hour in a variable that will not change
const uint8_t h = now.hour();
// If hour > 12 then subtract 12, else if hour == 0 use 12, else unchanged
LCD.print((h > 12) ? h - 12 : ((h == 0) ? 12 : h), DEC);
LCD.print(':');
LCD.print(':');
// AM if hour < 12, else PM
LCD.print((h < 12) ? " AM" : " PM");
I am the Possum, and I approve of this message. Sent from MacBook Wheel Sorry for my bad German.
oPossum
by obbi13 on Sun Jan 02, 2011 7:05 pm
oPossum, thanks for the help, it worked nicely, although I had to modify the following line:
because I was getting an overloading error on the LCD.print() function not being able to test numeric values and print chars at the same time. Plus I took the time to pad the time elements with zeros if less than 10. Here's the final code I ended up with on the time function:
void printClock(){
    LCD.clear();
    LCD.cursorTo(1,1);              // Functions to move the cursor to first line fisrt position
    LCD.print("Date ");
    if(now.month() < 10){           // Zero padding if value less than 10 ie."09" instead of "9"
      LCD.print("0");
    LCD.print('/');
    if(now.day() < 10){            // Zero padding if value less than 10 ie."09" instead of "9"
      LCD.print("0");
    LCD.print('/');
/*************  Now comes the time section  **************/
    const uint8_t hr_12 = h%12;
    LCD.cursorTo(2,1);              // Functions to move the cursor to second line fisrt position
    LCD.print("Time ");
    if(hr_12 < 10){                // Zero padding if value less than 10 ie."09" instead of "9"
      LCD.print(" ");
      LCD.print((h > 12) ? h - 12 : ((h == 0) ? 12 : h), DEC); // Conversion to AM/PM
    else{
    LCD.print(':');
    if(now.minute() < 10){         // Zero padding if value less than 10 ie."09" instead of "9"
      LCD.print("0");
    else{
    LCD.print(':');
    if(now.second() < 10){        // Zero padding if value less than 10 ie."09" instead of "9"
      LCD.print("0");
    else{
    if(h < 12){                  // Adding the AM/PM sufffix
      LCD.print(" AM");
    else{
      LCD.print(" PM");
obbi13
by csracruisers on Mon Feb 18, 2013 11:04 pm
How is the best way to add the day of the week to this code.
I have seen several uses of switch(dayOfWeek) but don't seem to be able to produce anything.
csracruisers
by adafruit_support_rick on Tue Feb 19, 2013 10:20 am
Easiest thing is to download the Arduino Time Library. Check out the TimeSerialDateStrings example.
by odometer on Tue Feb 19, 2013 3:20 pm
I don't think you need to download another library. Here's why:
It seems already have RTClib. RTClib has a dayOfWeek method. I suggest using something like this:
switch (now.dayOfWeek()) {
  case 0: LCD.print("Sun"); break;
  case 1: LCD.print("Mon"); break;
  case 2: LCD.print("Tue"); break;
  case 3: LCD.print("Wed"); break;
  case 4: LCD.print("Thu"); break;
  case 5: LCD.print("Fri"); break;
  case 6: LCD.print("Sat"); break;
This goes in your printClock function.
(Ladyada, you might want to mention the dayOfWeek method in the docs.)
odometer
by adafruit_support_rick on Tue Feb 19, 2013 6:50 pm
@odometer - actually, the proper way to do that is with an array of characters (which is what the Time library does, btw). I was originally considering posting that, but I decided that the Time library offers a whole lot more than just this one thing, so the OP might be better off with it in the long run.
char* dayStr[] = { "Sunday",  "Monday",  "Tuesday",  "Wednesday",  "Thursday",  "Friday",  "Saturday" };
Serial.print(dayStr[now.dayOfWeek()]);
by csracruisers on Wed Feb 20, 2013 4:21 pm
driverblock wrote:Easiest thing is to download the Arduino Time Library. Check out the TimeSerialDateStrings example.
Thank you for the info. After looking at the link, I was able to get what I needed.
csracruisers
by lovligirl on Mon May 05, 2014 5:35 am
kindly help me with one thing that is i m using RTClib which is so good but i want to adjust time with up down button is it possible if i use RTC.adjust(manul_set(date,time) in this format i mean i declare adjust style but with my own function please tell me because as far as i learned there is i hve to change the library to time.h and DS1307RTC.h to make a manual set but i think the adjust fuction will work like this please tell me
lovligirl
by adafruit_support_rick on Mon May 05, 2014 2:20 pm
The adjust function will work. You need to create a DateTime object and set it to the correct time, then you can call adjust.
There are many different ways to do this, but the simplest way would be to get the current time with rtc.now().secondstime(), then add or subtr5act the correct number of seconds according to the up/down button press.
For instance, to increase the hour by 1, you would add 3600 seconds. To decrease the hour by 1 you would subtract 3600 seconds.
by lovligirl on Mon May 05, 2014 4:14 pm
thank u very much for the help i m making it i have another question about clock and that is i m using ds1307 but sometime it reali blurr i mean reading suddenly stuck on 45:165:165 kind of so i decided to work with ds3231 but my question part1 is can i use ds1307 with only wire.h library is it possible and question part2 is; is ds3231 is best alternat of ds1307 or is it just my assumption because ds3231 works on wire.h only library so i liked it and have an relitivli easy way to set date and time with buttons please tell me thank u
lovligirl
by adafruit_support_rick on Mon May 05, 2014 4:24 pm
lovligirl wrote:but sometime it reali blurr i mean reading suddenly stuck on 45:165:165
We have seen that. It is a symptom of a bad connection. Check your power and SDA an SCL connections.
Otherwise, the DS3231 is compatible with the ds1307. The instructions and libraries are the same.
by lovligirl on Mon May 05, 2014 5:13 pm
thank u so much for ur reply ur site is the best ever
lovligirl
by adafruit_support_rick on Mon May 05, 2014 5:17 pm
by lovligirl on Wed May 07, 2014 2:49 pm
hi i want to ask question about triac dimmer but i want to post in recent page please tell me if it is??
lovligirl
