Assembled the clock, and daliclock came up working fine. I soldered the header for the usb port in, which makes assembling the case "interesting", but got it done...
Then tried to put in the seven segment clock (an aside here: where, exactly, are the *.hex files? Whichever clock you choose, you seem to end up in the same place?) and got:
C:\>avrdude -c arduino -P COM8 -p m328p -b 57600 -U flash:w:monochron.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "monochron.hex"
avrdude: input file monochron.hex auto detected as raw binary
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 16.12s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against monochron.hex:
avrdude: load data flash data from input file monochron.hex:
avrdude: input file monochron.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 13.84s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x7800
0x65 != 0x0c
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Went to the daliclock area (I think) and tried that:
C:\>avrdude -c arduino -P COM8 -p m328p -b 57600 -U flash:w:monochrondali.hex
avrdude: reading input file "monochrondali.hex"
avrdude: input file monochrondali.hex auto detected as raw binary
avrdude: verifying flash memory against monochrondali.hex:
avrdude: load data flash data from input file monochrondali.hex:
avrdude: input file monochrondali.hex contains 32768 bytes
Reading | ################################################## | 100% 13.81s
0x23 != 0x0c
So, what should I be looking for?
Thanks all in advance.
Bad firmware load on what was a working monochron
Re: Bad firmware load on what was a working monochron
does it work?
It displays a random pattern on the lcd, and flashes. It doesn't work.
Well, duh. The 32768 byte file I was downloading wasn't the 7-segment, or the dali. I took monochron.hex from firmware on the page you get to when you click on Code at GitHub on the http://www.ladyada.net/make/monochron/newclock.html page...but that gets you to a page where, if you select "firmware" you don't get the 7-segment code, but something else... I had ignored the "Download" button.
Sorry for the wasted bandwidth, and your time.
