Hi, name is denny srun. I have a question on the ice tube clock. I soldered all the components onto the board and when I tested out the voltage on the multimeter it read 3230mV and the display didn't turn on when I plugged in the ac adapter that came with it. What could be the problem??
thanks, denny
ice tube clock
Re: ice tube clock
In the tutorial, there were several voltage tests to perform before installing the VFD chip or assembling the display. What were the results of those tests?
What is the output of the boost converter with the VFD chip and tube not installed?
If you post clear photos of the front and back of the boards we can look for any assembly problems.
Re: ice tube clock
i see three mistakes so far i put the chip holder incorrectly, one of the diode is reversed, and transistor is reversed.
Re: ice tube clock
The photos are a little fuzzy, but it looks like you have both transistors (Q2 and Q3) installed backward.
It is important to follow the instructions and perform all the tests:
If one of the tests fails, DONT KEEP GOING! Stop, try to get the test working again and post in the forums if you're stuck. If you keep going it will not magically fix itself and you'll have much more to try to debug...
