Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
Another Ice Tube Clock Firmware for the Holidays
Re: Another Ice Tube Clock Firmware for the Holidays
by Daave on Wed Mar 26, 2014 8:13 pm
Yep, you were right. I messed up something with the configuration with my makefile.
I just hit the reset switch and deleted all the files, unzipped them again, and remade the Makefile. Making the change from -B 4 to -B 25 was still necessary. Thanks for the prompt help :)
As a side note, the value of 25 is rather arbitrary. 16 was the minimum that let avrdude see my device, but I had to raise it. The higher the number, the slower the transfer speed was to my device. In other words, 25 is safe, but it can easily be raised or lowered. If the new value doesn't work with the data transfer, you will see an error.
Daave
by jarchie on Wed Mar 26, 2014 10:59 pm
Thanks for the update. I'm glad things worked out.
--John <www.jarchie.com/email>
jarchie
by MikeHg on Fri Nov 28, 2014 7:59 am
I just want to say Thanks! for this great firmware. I flashed it yesterday and it just worked from the beginning. I'm amazed by the options and my clock is even more accurate now due to the built in correction.
The clock really feals like completey renovated!
So thanks again, John!
Best regards,
Mike
PS: This was also the first time I programmed an AVR (I used my arduino for that). Your description was so detailed that I didn't even need other documents (apart from the arduinoisp page). Great documentation!
MikeHg
by jarchie on Sat Nov 29, 2014 3:39 pm
Hello Mike,
I'm delighted that you are enjoying the firmware and appreciate the feedback. Thank you!
I spent a fair bit of time on the documentation and was glad to hear that it was helpful for you.
Congratulations especially on programming an AVR for the first time... and with the ArduinoISP sketch, no less! I personally found programming with an Arduino to be a bit tricky.
Cheers,
John
jarchie
by wildtang3nt on Wed May 27, 2015 7:26 am
Hey John, I've got a bit of info on battery depletion to share. I left my clock unplugged and boxed up for nearly 6 months, maybe longer, and recently started using it again in the last two months, and it is only now that I get a BAD BATT message when it turns on. And that battery was already somewhat used before :P
wildtang3nt
by jarchie on Thu May 28, 2015 2:51 pm
Excellent! And thanks. I don't usually leave my clock unplugged for too long, so it's good to hear that the extended battery life and "bad batt" warning work as expected.
jarchie
