Help with a weird problem on Ice Tube Clock
Re: Help with a weird problem on Ice Tube Clock
Voltage from Gnd to stripe end of D3 is 13.5
Curiously Pin 28 on the Atmel part came with no tip on the it. It had enough to make it into the socket, just a FYI.
Frank_tt wrote: My problem is when I plug in the unit, the numbers show up dim for a couple seconds and flash as they are supposed to, but then the segments start dropping off line and after a few more seconds the display is dark.
Frank_tt wrote:Also I noticed when it starts flashing the numbers for the first few seconds (while I can read them) it is counting every 2 seconds..... flash(08)....flash(10).....etc.
