Monochron fails beep test
by tsdaniel on Thu May 01, 2014 7:09 pm
I am in the process of building the monochron clock. The board fails the second beep test. The voltage still is at 5.07 as it was for the first test. I'm including a photo of the back of the board.
Back of board
tsdaniel
Re: Monochron fails beep test
by adafruit_support_bill on Thu May 01, 2014 9:17 pm
Do you mean the test after the switch and indicator LED are installed?
Please post a photo showing the entire back of the board. And one of the front as well.
by tsdaniel on Thu May 01, 2014 9:36 pm
It was the second test after installing the speaker and before the LED is installed. I tried including an edge to edge photo but it was too large to post so I cropped it. The photo does have all the connections. I can try and post it in two sections. Here's a photo of the front of the board.
Front of board
tsdaniel
by adafruit_support_bill on Fri May 02, 2014 5:44 am
OK. So it was the second test, but the first test involving a beep? You solder looks fine and everything is in the right place. I suspect you may have a processor that was not successfully flashed with the firmware. If you contact support@adafruit.com with a link to this thread we can get a replacement out to you.
