undefined reference in "RTClib.h"
by normlane on Thu May 22, 2014 11:14 pm
It looks like "secondstime" is declared in the header file but not defined in cpp. Shouldn't that be "secondsTime" anyway? (and unixtime as unixTime for that matter.)
normlane
Re: undefined reference in "RTClib.h"
by adafruit_support_rick on Fri May 23, 2014 12:09 pm
Are you getting an error? That library has been around for ages.
by normlane on Sat May 24, 2014 2:32 pm
Yeah, here's the error...
saveTime.cpp.o: In function `setup':
C:\arduino/saveTime.ino:36: undefined reference to `DateTime::secondstime() const'
My code...
Serial << newTime.unixtime() << endl;
Serial << newTime.secondstime() << endl;
The unixtime() call works.
Perhaps no one has had a reason to use that function before? I want to initialize a DateTime object with a 32 bit number instead of text. Now that I look more closely I think I should be using unixtime() anyway. For some reason the code seems to expect that but when you initialize with text it chokes on valid unix times with a year less than 2000 and adds an extra 100 years. 1999 will turn into 2099. If you get under the hood this library is a little odd.
Anyway, the missing code for secondstime() is a bug but it's apparently not very critical if no one else has tried to use it.
normlane
by adafruit_support_rick on Sat May 24, 2014 6:06 pm
That is bizarre. I guess you're the first person to try to use that function.
The function itself is pretty simple - it's just unixtime without the constant add:
uint32_t DateTime::secondstime(void) const {
  uint32_t t;
  uint16_t days = date2days(yOff, m, d);
  t = time2long(days, hh, mm, ss);
  return t;
by McSummation on Mon Jun 30, 2014 7:21 pm
I just ran into the same issue. Could you fix the cpp file and reupload it?
McSummation
by normlane on Tue Jul 01, 2014 12:05 am
Take care. Some of the DateTime init code expects unixtime not secondstime.Check the code in the library.
normlane
by adafruit_support_rick on Tue Jul 01, 2014 10:38 am
OK . The library is updated on github. Grab a fresh copy and give it a try
by McSummation on Tue Jul 01, 2014 3:20 pm
I grabbed the update, changed unixtime to secondstime in my sketch and it works properly. Thanks.
McSummation
