Ice Tube Clock
Ice Tube Clock
by Guillaume_Lalande on Fri Jun 20, 2014 8:14 am
I soldered all the circuit components and the brightness of seconds is not adustable. I think is a hardware problem.
[/img]\Desktop\Clock.JPG[/img]
Guillaume_Lalande
Re: Ice Tube Clock
by adafruit_support_bill on Fri Jun 20, 2014 8:53 am
You photo is not showing up. Use the "Choose File" button under the message editing box to select your image file, then select "Add The File" to upload it.
Re: Ice Tube Clock
by Guillaume_Lalande on Fri Jun 20, 2014 1:34 pm
The seconds are less brite.
Guillaume_Lalande
Re: Ice Tube Clock
by adafruit_support_bill on Fri Jun 20, 2014 4:03 pm
This is a known phenomenon and is a function of the way the tube is driven. It is mentioned in the FAQ (see last question) https://learn.adafruit.com/ice-tube-clock-kit/faq
Some customers have developed firmware modifications to address this issue: viewtopic.php?f=41&t=23586&p=175883
Re: Ice Tube Clock
by jarchie on Fri Jun 20, 2014 5:08 pm
The Adafruit design drives the IV-18 filament with ~2.5v of direct current, and the IV-18 filament was designed to be driven by ~5v of alternating current. On some tubes, the Ice Tube Clock is unable to sufficiently heat the filament, and the result is a final and/or initial digit that is noticeably dimmer. This dim digit issue can be resolved by replacing Q3 with a transistor capable of providing more power to the IV-18 filament.
I suggest the ZVP2110A, available from Digi-Key (ZVP2110A-ND) or Mouser (522-ZVP2110A). Another excellent alternative is the is the PN2907A/resistor combination described by Russell27. Both solutions will provide additional power to the IV-18 filament and even out the display.
jarchie
