URGENT Ice Tube Clock Kit Adapter Issue
by sghauri on Fri Aug 22, 2014 1:38 pm
Hi
I received my Ice tube clock kit today, Thank you for that,
I ran into small problem, the 9V adapter - I am based in the UK where we have three pin plugs and three pin sockets, The adapter only has two pins - My question is it okay just to use an two pin to three pin adapter? Will this cause any problems to the circuit?
If not can you point me in the right direction ( like an alternative adapter I can use??)
Thank you
sghauri
Re: URGENT Ice Tube Clock Kit Adapter Issue
by adafruit_support_bill on Fri Aug 22, 2014 2:16 pm
It is rated to handle your 240v/50Hz mains supply. It should work fine with a two to three prong adapter.
by sghauri on Fri Aug 22, 2014 2:46 pm
Thank you
sghauri
