I'm working on a GPS clock that will express each hour with different color (12 would be red and the fading to yellowish until green around 3 o'clock). I was trying to modify NeoPixel Ring Clock, but didn't succeed. I'm using flora with GPS and NeoPixel strip. Do you guys have any advise where to search for a fix? I tried youtube and google, but it seems that everyone is showing time by moving pixels, where I want to play with color.
Rainbow GPS clock
Re: Rainbow GPS clock
What exactly is broken? If you can describe the problem more precisely and post the code you are using someone might be able to help.Do you guys have any advise where to search for a fix?
- kldfkw
Where should I search for more tutorials with GPS clock and NeoPixels that will change color instead of location to reflect the time.
I tried using currentHour with if function to set the color of the strip, but didn't work. Any guides/readings that you can recommend for me?
- kldfkw
Here's my code - can anyone help or just advise me some tutorials that will help me understand changing the color of the NeoPixel while GPS time passes
https://codebender.cc/sketch:140842
Take a look at the 'strandtest' sketch from the neopixel library. There is a 'Wheel' function that maps a value from 0-255 into a color of the rainbow.
To map an hour into a wheel color, you first need to convert it to a value between 0 and 255. This can be done with the map() function:
https://www.arduino.cc/en/reference/map
So if you add the Wheel() function to your program, your code could look something like this:
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
uint32_t color = Wheel(map(hour, 0, 11, 0, 255));
strip.setPixelColor(color);
