Black Nixie Tube
Black Nixie Tube
by sprite on Sun Oct 04, 2015 4:26 pm
My Nixie tube is black/burned on the back. Is this normal or do I need a replacement? Don't want to solder it to the board until I know if I need to replace it or not.
sprite
Re: Black Nixie Tube
by cconradd on Sun Oct 04, 2015 5:57 pm
Normal.
I also wondered this at first but after some googling it appears they all look this way.
cconradd
by sprite on Sun Oct 04, 2015 6:42 pm
sprite
by jarchie on Sun Oct 04, 2015 7:02 pm
The black spot is actually an important part of the tube design. Vacuum tubes require an almost perfect vacuum, but removing all gas is nearly impossible. Even worse, the tube walls and other components release absorbed gas long after manufacture. The black spot, called a "getter," is added during manufacture. The getter is composed of reactive material that binds gas. So the black spot is effectively a chemical vacuum pump and is active for the life of the tube.
jarchie
