Ice Tube Clock Kit: Boost converter only generating 30v
by squeaker on Sat Oct 10, 2015 3:05 pm
I'm on step 36 in the ice tube clock kit assembly process, and I'm only getting 30V out of my boost converter. I've tried a couple different power supplies, the included 5V and a 12V I had lying around. Same result with either.
Higher resolution photos are available at this imgur link.
The jumper wire runs from R1 to C4 because I managed to burn off one of the contact pads while desoldering/resoldering the wrong part. Done from info I got from this post.
squeaker
Re: Ice Tube Clock Kit: Boost converter only generating 30v
by jarchie on Mon Oct 12, 2015 3:34 am
Since no one else has replied, I'll weigh in. It's been a while since I built my Adafruit Ice Tube clock, but I believe my voltage was similarly low. I finished building the clock anyway and everything worked fine. So I would suggest proceeding with the build.
jarchie
