Soft/Hard RTC code simplified?
by fmbfla on Sat Nov 21, 2015 11:38 pm
Not sure if any one needs this but I got board tonight and did this for myself for a few projects. I kept getting mad because I had to always induce the "DateTime now = rtc.now();" every time I needed something to do with the Date or time. the footprint is not much bigger than the stock Softrtc and can be used either Hard or soft.
Make me happy.
Fmbfla
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
// With 12 hour conversion and Simplification
#include <Wire.h>
#include "RTClib.h"
char* month[] = {
  "null", "January,", "Febuary", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"
char* weekDays[] = {
  "Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"
// Below is so an Emic T2S mod will sound human
char* day[] = {
  "null", "First", "Second", "Third","Forth", "Fifth", "Sixth", "Seventh","Eighth", "Nineth", "Tenth", "Eleventh", "Twelfth","Thirteenth","Fourteenth","fifthteenth","Sixteenth","Seventeenth","EightTeenth","Nine Teenth","Twenty eth","Twenty first","Twenty Second","Twenty third","Twenty Forth","Twenty Fifth","Twenty Sixth","Twenty Seventh","Twenty Eighth","Twenty Ninth"," Thirty eth","Thirty First"};
int Year;
int Month;
int Day;
int Hour;
int Minute;
int Second;
int dayOfWeek;
//RTC_DS1307 rtc;  // Hardawre
RTC_Millis rtc;  // Software
void setup () {
  Serial.begin(115200);
  /*---------------HARDWARE RTC------------------------*/
  //  The Eight (8) Lines Below are for HARDWARE RTC
  /*  rtc.begin();  // Uncomment for HARDWARE RTC
      if (! rtc.isrunning()) {
      Serial.println("RTC is NOT running!");
      // following line sets the RTC to the date & time this sketch was compiled
      rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
      // This line sets the RTC with an explicit date & time, for example to set
      // January 21, 2014 at 3am you would call:
      // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
  /*---------------SOFTWARE RTC------------------------*/
  //  rtc.adjust(DateTime(__DATE__, __TIME__));  // Uncomment for HARDWARE RTC
  //  The Single Line below is for SOFTWARE DEFINED RTC
  rtc.begin(DateTime(F(__DATE__), F(__TIME__)));  // Uncomment for SOFTWARE RTC
  //rtc.begin(DateTime(2014, 1, 21, 3, 0, 0));  // Uncomment To set a Specific Date and Time using SOFTWARE RTC
void loop () {
  save_time();
  save_time_conversion();
  Serial.print("24 Hour Time: ");
  Serial.print(Hour);
  Serial.print(':');
  Serial.print(Minute);
  Serial.print(':');
  Serial.print(Second);
  Serial.print(' ');
  Serial.print("Date ");
  Serial.print(Year);
  Serial.print('/');
  Serial.print(Month);
  Serial.print('/');
  Serial.println(Day);
  Serial.println();
  Serial.println();
  delay(3000);
void save_time() {
  DateTime now = rtc.now(); // never needs to be called upon again
  Year = now.year();
  Month = now.month();
  Day = now.day();
  Hour = now.hour();
  Minute = now.minute();
  Second = now.second();
  dayOfWeek = now.dayOfWeek();
void save_time_conversion() {
  //Serial.print("Date ");
  Serial.print(dayOfWeek[weekDays]);
  Serial.print(' ');
  Serial.print(Month[month]);
  Serial.print(' ');
  Serial.print(Day);
  Serial.print(',');
  Serial.print(' ');
  Serial.println(Year);
  // Save_time with the Twelve Hour conversion added
  //Serial.print("12 Hour Time: ");
  if (Hour < 10) {              // Zero padding if value less than 10 ie."09" instead of "9"
    Serial.print(" ");
    Serial.print((Hour > 12) ? Hour - 12 : ((Hour == 0) ? 12 : Hour), DEC); // Conversion to AM/PM
  else {
  Serial.print(':');
  if (Minute < 10) {       // Zero padding if value less than 10 ie."09" instead of "9"
    Serial.print("0");
    Serial.print(Minute, DEC);
  else {
  Serial.print(':');
  if (Second < 10) {       // Zero padding if value less than 10 ie."09" instead of "9"
    Serial.print("0");
    Serial.print(Second, DEC);
  else {
  if (Hour < 12) {                // Adding the AM/PM sufffix
    Serial.print(" AM ");
  else {
    Serial.print(" PM ");
fmbfla
Re: Soft/Hard RTC code simplified?
by adafruit_support_bill on Mon Nov 23, 2015 9:07 am
Nice! Thanks for posting.
