DS1307 RTC 3.3v Board
by krt72012 on Thu Dec 10, 2015 10:50 am
I'm having trouble getting my DS1307 RTC working with my 3.3v microcontroller (M0). I have a coin cell in it.
I always get this message no matter how i modify my code:
RTC is NOT running!
(165/165/2165 - 165:165:85)
I've tried adjusting it in every way I can find and it still remains at that weird time. I have the two resistors removed to keep I2C down to 3.3 V.
I've tried powering it from a USB port (@5v standard) and from a 5V wall outlet.
void initRTC()
  Wire.begin();
  rtc.begin();
  if (! rtc.isrunning())
    Serial.println("RTC is NOT running!");
    writeSD("RTC is NOT running");
    //rtc.adjust(DateTime(2015, 12, 9, 11, 18, 0));
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(__DATE__, __TIME__));
  DateTime now = rtc.now();
  String timestring = "(";
  timestring = timestring + now.month();
  timestring = timestring + '/';
  timestring = timestring + now.day();
  timestring = timestring + now.year();
  timestring = timestring + " - ";
  timestring = timestring + now.hour();
  timestring = timestring + ':';
  timestring = timestring + now.minute();
  timestring = timestring + now.second();
  timestring = timestring + ')';
  timestring = timestring + ' ';
  Serial.println(timestring);
krt72012
Re: DS1307 RTC 3.3v Board
by adafruit_support_rick on Fri Dec 11, 2015 3:08 pm
You need the pullup resistors. You can replace them and try powering the DS1307 with 3.3V. Or you can connect the resistors between SDA and 3.3V and SCL and 3.3v
by krt72012 on Fri Dec 11, 2015 4:35 pm
adafruit_support_rick wrote:You need the pullup resistors. You can replace them and try powering the DS1307 with 3.3V. Or you can connect the resistors between SDA and 3.3V and SCL and 3.3v
Just tried both and still getting the same output.
krt72012
by adafruit_support_rick on Sat Dec 12, 2015 12:02 pm
We've seen this exact problem before. It almost always comes down to wiring issues.
But we can try replacing the RTC. Please email support@adafruit.com with a link to this thread for a replacement. When you get it, try it with a Uno or on a breadboard before you solder it into your system.
by krt72012 on Mon Dec 14, 2015 10:47 am
adafruit_support_rick wrote:We've seen this exact problem before. It almost always comes down to wiring issues.
Yeah I've looked on other threads to see if there was a solution that worked for me. And I've triple checked all my connections; it's odd.
Thank you very much for the help. I buy a lot of things from Adafruit and the excellent customer service keeps me coming back.
krt72012
