All segments lit—no other function
by secnerret on Thu Jan 28, 2016 12:20 am
Bright, all segments illuminated
Finally built the kit I ordered in 2011 and it doesn't exactly work. All segments are lit. Beeps on startup; menu button does nothing.
secnerret
Re: All segments lit—no other function
by jarchie on Thu Jan 28, 2016 12:41 am
The all-segments-lit problem is usually due to a flaky Q3. The jumper test can confirm that Q3 is the cause in your clock. Adafruit will likely offer to replace Q3 with a better part (the ZVP2110A), assuming Q3 is the culprit.
jarchie
by secnerret on Sat Jan 30, 2016 11:55 am
I've now tried the Q3 jumper with no change—all segments still lit and unchanging.
Q3 jumper
Any other ideas? I've added pics of my board.
All Segments on #1
All segments on #2
secnerret
by adafruit_support_bill on Sat Jan 30, 2016 12:09 pm
Don't see any obvious issues there. Can you post one of the solder-side of the tube board also?
by secnerret on Sat Jan 30, 2016 12:37 pm
Tube board. (I checked for continuity between the points just left of 12 o'clock and there is no short—only potential problem I could see.)
secnerret
by jarchie on Sat Jan 30, 2016 1:07 pm
Looking at your board, I see one microcontroller pin that looks unsoldered, but that could just be the light. This pin is used in sending the display information to the VFD driver chip, so a bad connection there might explain your display issues.
Possibly unsoldered pin
jarchie
by secnerret on Sat Jan 30, 2016 1:23 pm
Thank you—the missed solder point was the problem. This is the first circuit board I've ever put together and I thought I was obsessively checking everything. And I was looking at it all again when it wasn't working, but somehow I just didn't see that missed pin. Thank you again, the clock now works without the Q3 jumper.
secnerret
by jarchie on Sat Jan 30, 2016 1:35 pm
Awesome! And congrats on your now working clock.
I've seen many experienced builders make (and miss) similar soldering issues, so don't feel too bad. It's all part of the process. :-)
jarchie
by adafruit_support_bill on Sat Jan 30, 2016 1:42 pm
Nice catch jarchie! Lighting can make that sort of thing tricky to spot.
