APA102-2020 not RoHS capable?
by zerkman on Thu Nov 30, 2017 1:10 pm
Hi All,
We're going into manufacturing with the APA102-2020 (dotstar LED).
https://www.adafruit.com/product/3587
Our manufacturer pointed out an interesting tidbit from the datasheet.
Even though these LEDs may be RoHS compliant, the reflow temperature profile listed in the datasheet seems to indicate that they're not actually RoHS compliant. The datasheet actually lists two different max temperatures. The table lists Tsldr as 235+/-5, but the diagram lists a range of 210-230. Our manufacturer is wanting to get up to 250 for all the other components on our board.
Does anyone have any experience using these LEDs in a RoHS process in manufacturing?
Thanks,
-Mike
zerkman
Re: APA102-2020 not RoHS capable?
by adafruit_support_mike on Thu Nov 30, 2017 6:11 pm
We use a standard lead-free process for them.. no special equipment, materials, or techniques are necessary.
The exact heating profile you use depends heavily on the on the board you want to reflow, so you’ll need do a few test runs to find what works. It shouldn’t be too hard though.
Datasheets only list the conditions where the manufacturer feels comfortable guaranteeing successful performance. The physical parts themselves can tolerate a much wider range of conditions, but it’s up to you to do your own testing if you go outside the suggested profile.
by zerkman on Fri Dec 01, 2017 11:20 pm
Thanks for the helpful feedback!
zerkman
