product 1163 with MAX7370
by ddownn on Tue May 22, 2018 10:51 am
I was wondering if the MAX7370 chip could be attached to this 32 pin breakout. I think the chip is 24 pins but I'm not sure if just putting it in the center of the breakout will work just leaving the remaining pins unused.
And if not, does anyone know of a suitable breakout PCB for this chip?
https://www.maximintegrated.com/en/prod ... X7370.html
"The device is offered in a 24-pin (3.5mm × 3.5mm) TQFN package with an exposed pad, and small 25-bump (2.159mm x 2.159mm) wafer-level package (WLP)"
ddownn
Re: product 1163 with MAX7370
by franklin97355 on Tue May 22, 2018 12:08 pm
The size of the die is 3.5mm and the board is for 5mm so it would not work. You might find something searching for SMT adapters. Schmartboard has quite a few but I did not do a search for yours.
franklin97355
by ddownn on Tue May 22, 2018 1:39 pm
Okay, thank you
ddownn
