Help with PCB design
by joshawatt on Thu Nov 15, 2018 10:30 am
I hope this is the right channel to ask this question, if not please let me know!
I am trying to design a circuit that uses the micro:bit edge connector (this one: https://www.adafruit.com/product/3888 ). I have never designed a PCB like this before because from what I have found there are no pre-built boar layouts for this item. How would I go about making it on say jlcpcb (that is what I use but I also have Eagle if that is a better way to do it). I have the datasheet for it as well, however I don't know the units of measurement, I assume it is in millimeters. (and now that I think about it, I will just measure it once I get home). I tried to create SMD pads in JLCPCB but I could not get it to route any connections.
joshawatt
Re: Help with PCB design
by adafruit_support_mike on Fri Nov 16, 2018 12:33 am
I'm afraid we don't know anything about JLCPCB, but we have a couple of tutorials about creating device footprints in Eagle:
https://learn.adafruit.com/creating-acc ... s-in-eagle
https://learn.adafruit.com/ktowns-ultim ... e-tutorial
Those walk through all the steps necessary to transfer measurements from the datasheet to a layout package, and then assign the connections the way Eagle does it.
