Peristaltic Pump help
by Britexpat on Thu Nov 14, 2019 12:59 pm
I'm a complete nube and need help with considering whether the peristaltic pump will serve my needs. For my project I was considering using two pumps to push water into and out of 4(total) bladders. The idea is that two bladders would be placed under padding on the forehead and chin of a person lying prone on a massage table, while the other two bladders would be under the cheeks. I would alternate filling the cheek and forehead/chin bladders in a pattern to ensure that no one area receive too much pressure during what might be a period of up to 12 hours.
Does this sound like a viable idea?
Thank you.
Ashley
Britexpat
Re: Peristaltic Pump help
by adafruit_support_bill on Thu Nov 14, 2019 1:21 pm
It could be possible depending on the size of the bladders and the expected load. In my experience, these pumps are capable of producing pressures of about 2 PSI. So, to support a 10 pound head, you would need a total contact area of 5 square inches or more.
by Britexpat on Thu Nov 14, 2019 1:40 pm
I was thinking of using some flexible sheet rubber to make the bladders, what size do you think they need to be?
Britexpat
by adafruit_support_bill on Thu Nov 14, 2019 1:55 pm
As mentioned above, you will need at least 5 square inches of contact to support 10 pounds. If only 2 will be pressurized at a time, then each one should have at least 2.5 square inches. If possible, larger is better. A bladder with a larger surface would reduce the required working pressure - which would put less stress on the pump - and probably be more comfortable for the person.
by Britexpat on Thu Nov 14, 2019 2:21 pm
Thank you, this is incredibly helpful.
Britexpat
by Britexpat on Thu Nov 14, 2019 2:45 pm
Anything else I need to consider?
Britexpat
by adafruit_support_bill on Thu Nov 14, 2019 2:56 pm
You will probably need a microcontroller board and motor driver to control the system. One of the Feather processors with a Motor Wing would be a good choice.
https://www.adafruit.com/category/830
https://www.adafruit.com/product/2927
