Dimensions of Adafruit Breakout Board
by vrdesai on Thu Nov 21, 2019 11:24 pm
I have purchased this board to prototype test a TSSOP 6-pin current sensor. My application requires pretty high locational tolerancing of the sensor and I was wondering if anyone knew what the exact dimensions and tolerances for this:
https://www.adafruit.com/product/1212
Adafruit board is. Would ask adafruit directly but all tech support is supposed to be through the forum. Thank you all for the help!
vrdesai
Re: Dimensions of Adafruit Breakout Board
by franklin97355 on Fri Nov 22, 2019 2:39 am
If you've purchased the board you should be able to measure the dimensions. Since you have to place the chip yourself precise measurements depend on your placement.
franklin97355
by adafruit_support_mike on Fri Nov 22, 2019 2:47 am
The design files are over in our Github repo:
https://github.com/adafruit/Adafruit-SMT-Breakout-PCBs
You can pull any dimensions you need from those.
