Solder Bridge on Inductive Charging Set
by conroydave on Sun Jul 31, 2016 12:58 pm
Hellow Adafruiters-
I bought two inductive charging sets (PRODUCT ID: 1407)
https://www.adafruit.com/product/1407
On the PCBs on both sides that you are supposed to connect power to have large solder bridges on the IC.
Am I safe to fire this up or should I just return them?
Thanks, in advance.
conroydave
Re: Solder Bridge on Inductive Charging Set
by adafruit_support_mike on Mon Aug 01, 2016 11:42 pm
I don't have one on hand to compare, but I'm pretty sure that's deliberate.
The wiring between the silicon die and the pin can only handle so much current, so it's common to see pins doubled up for high-current signals.
Let me confirm that with someone who can check the hardware though.
by adafruit2 on Tue Aug 02, 2016 2:18 pm
yeah thats not unusual - a common technique with high power pins - please try it out
adafruit2
Site Admin
