๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Surface mounting Pi zero "spy" camera
by hjelstromboli on Mon Jul 24, 2017 4:34 am
I'm looking for a reliable way to constrain the "pi zero spy camera" to a pcb. Is soldering back plate of the camera to a large pad a plausible idea? Is it safe to pass the camera through a reflow oven?
Brandon
hjelstromboli
Re: Surface mounting Pi zero "spy" camera
by adafruit_support_mike on Mon Jul 24, 2017 11:20 pm
The plastics of the lens assembly probably wouldn't make it.
A lower-temperature option would be to use fusible interfacing.. basically hot-melt glue in tape form, used in sewing. I use it to tack pieces of copper-clad together all the time. Dry-mount film, used for mounting pictures, is another version of the same thing.
by hjelstromboli on Wed Jul 26, 2017 1:22 am
Mike,
Thank you for your suggestion. Currently looking into the hot melt tapes you mentioned. I also came across the use of jb-weld on pcbs, which looks like it could be an even more permanent solution. In any case, I think I can figure this out now.
-Brandon
hjelstromboli
