๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Ground Plane trouble with FGPMMOPA6H
by Adam_Xstream on Wed Oct 25, 2017 9:45 pm
Hello Adafruit Community.
I'm struggling to get performance from our FGPMMOPA6H GPS module which we have mounted to our custom PCB. We really liked the performance of this chip when we used it as a breakout board, however, when we mount it to our PCB the module is unable to find a fix.
I was hoping to check in with the community and see if others had successfully mounted this module to their designs and if they had any problems like the ones we are having.
I am also interested in people's thoughts on our use of ground plane below the chip. We did this to isolate it from noise, but its so different from the original breakout board, I am concerned we inadvertently messed up one of the features.
FGPMMOPA6H Datasheet
https://cdn-shop.adafruit.com/datasheets/GlobalTop-FGPMMOPA6H-Datasheet-V0A.pdf
Thank you for your help!
Adafruit mounting. These board work wonderfully! However, they have traces going directly under the module!
Adafruit Ultimate Breakout Board.png (141.6 KiB) Viewed 1240 times
Our way of mounting to the PCB. Notice the large ground plane (Purple). We thought this would improve performance, but maybe we've made it worse by doing this?
Adam Mouting GPS.png (48.11 KiB) Viewed 1240 times
Adam_Xstream
Re: Ground Plane trouble with FGPMMOPA6H
by adafruit_support_mike on Thu Oct 26, 2017 12:18 am
You have to be careful about the spacing of a gound plane near an antenna.
The fixed 0v surface acts like a mirror for radio waves, and the reflections will make a single-wire dipole antenna see what amounts to a copy of itself an equal distance behind the plane. With the right combination of distance from the ground plane and electrical path distance through the antenna, you can get the effect of an antenna twice as wide. Other combinations can cause interference that cancels the signal though, making the signal reception worse.
Try etching away the ground plane below the GPS module on one of your boards and see if that makes things any better.
Beyond that, you really need a simulator with a good RF package to get the details right. Small changes can make a big difference in performance.
