NEED SOLDERING HELP
Re: NEED SOLDERING HELP
by jps2000 on Thu May 10, 2018 3:51 pm
Just some thoughts:
A via is less reliable than a copper track. I would connect the capacitors with vias rather than data lines. If the former fail likely nothing will happen.
Wrapping a flexible board around a cylinder will result in a polygon (straight below stiff components. So you better glue it with double sided tape that is 1-2mm thick (soft).
Consider also coating the assembled board with flexible translucent ??? silicone ???
--> ask supplier
I have no experience with flex PCB in fabrics.
No risk no fun !
jps2000
by Sajeel on Fri May 11, 2018 4:20 am
One last question I want to ask....
What should be the width of data/clock track for neopixels in flexible pcb?? I have seen normally circuit designers chose 10mils but i have a curiosity to know what if I use 16mil wide data/clock track? Does greater track width sustain long upon stress??
Sajeel
by jps2000 on Fri May 11, 2018 6:23 am
The more width the better is it ;
Avoid sharp edges.
good luck!
jps2000
by Sajeel on Fri May 11, 2018 6:49 am
What f I use round tracks for data/clock signal in order to avoid sharp edge tracks? what do you recommend....
round tracks.JPG (33.45 KiB) Viewed 470 times
Sajeel
by jps2000 on Fri May 11, 2018 7:22 am
Round is likely better but not a must. And you may use teardrops from pads / vias to track.
Fix mount flex prints are much less critical than permanently moving arrangements.
go ahead!
jps2000
by Sajeel on Sat May 12, 2018 11:26 am
I have seen this thing (*please see yellow box) in your 8x8 rgb neopixel led panel and i want to know what is that?
Best regards
Sajeel
Sajeel
