๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
How to repair/replace PCB soldering plate
Re: How to repair/replace PCB soldering plate
by adafruit_support_mike on Tue Oct 30, 2018 12:52 am
Those are called 'pads', and replacing the ones shown in the photo will be a challenge.
Sometimes you can replace a pad with a small piece of wire, but that won't work in this case. You'd have to use the full-scale rework technique of removing some soldermask around the missing pads, cutting small pieces of copper foil to replace the missing pads and overlap the exposed copper that's still there, gluing the foil to the PCB with high-temperature epoxy, then soldering the foil to the existing traces to make the electrical connections.
