Does anyone know what happened to MDC Japan?
Re: Does anyone know what happened to MDC Japan?
by mikeanton on Fri Feb 05, 2021 7:33 pm
You should be able to scan a square part using the laser without problems. There is nothing to prevent square parts from being used, but if the part is rectangular, then the long side should be scanned first. You may need to relax the tolerance settings. Try to use 50%, and see if it works any better.
If the pins are very thin, you may not be able to use the pins for alignment. In that case, hopefully scanning the body is good enough.
mikeanton
