Mydata how-to and bit of hacking ....
Re: Mydata how-to and bit of hacking ....
by alphatronique on Sun Nov 10, 2013 4:04 pm
Hi
ok bit more update on my PIII hack ....
got today my second main-board whit "normal" bios on it ,so remove bios chip erase it and flash the Mydata one into it and noting :cry:
so was bit perplex ,have check all IC on the board for find another memory chip whit no luck
use of award bios explorer and un-packer have show noting interesting on the bin file and no Mydata ASCII text string
i lack of new idea now any suggestion was welcome
for info this is the main board mydata use
http://web.archive.org/web/200112242028 ... at915.html PIII 700 (PF2)
http://web.archive.org/web/200201111106 ... at840.html P1 233MMX
Best regard
Marc Lalonde CID.
IPC Certified PCB Designer.
Alphatroniqe inc.
www.alphatronique.com
http://ca.groups.yahoo.com/group/MyData_Group
alphatronique
by alphatronique on Fri Nov 15, 2013 12:28 pm
Hi
for help management of all mydata related stuff and avoid to cannibalize adafruit forum
i setup a yahoo group for mydata
http://ca.groups.yahoo.com/group/MyData_Group/
will still keep it here update but group was bit better for organise data
Best regard
Marc Lalonde CID.
Alphatroniqe inc.
alphatronique
by Daver5 on Wed Dec 11, 2013 8:31 am
Hi All,
I wanted to run this by to see if anyone can please help me. I have been seeing some strange light curtain errors upon initialization and operation on my TP9-UFP. I say strange because sometimes they occur with no feeders on the machine. Does anyone have a calibration procedure for this system, or any diagnostic tips for testing. Is there an amplifier or power supply maybe getting funky. Is there a way to bypass for troubleshooting. I have also seen a few MOT errors occur sometimes with this, but don't k now if one is affecting the other. Any help would be appreciated. Thank you. Dave
Daver5
by alphatronique on Wed Dec 11, 2013 9:59 am
Hi
you may check this ,got similar issue some time ago
viewtopic.php?f=42&t=33966&start=15#p202516
normally feeder was under the light curtain so it not matter ,it designer more for
detect operator hand placed at verry wrong place ;-)
a good start may check power supply ,you have TP being the computer box
refer to picture .. even if it write +/-80 usual was more +/-75v what really mather
was AC voltage that may appear if one of the filtering cap was dead
then most comme error source was card dirty connector ot not well seated on the backplane
have more detail about mot card error may also help for figure what wrong
hope it help
power supply test point on back of computer box
Best regard
Marc Lalonde CID.
Alphatroniqe inc.
alphatronique
by Daver5 on Thu Dec 12, 2013 12:16 am
Hi Marc,
Thank you for your response. The machine powered up cleanly today and ran all day with no issues. I'll keep notes on any MOT errors I see and get them over to you. Thanks again, Dave
Daver5
by alphatronique on Thu Dec 12, 2013 2:02 pm
Hi
if happen take picture of the monitor screen
code show permit to track down what happen , most of time it related to mechanical
Best regard
Marc Lalonde CID.
Alphatroniqe inc.
alphatronique
by Daver5 on Sun Dec 15, 2013 6:30 pm
Hi Marc,
I pulled out my notes from the last time the machine went into the error condition. The message was as follows:
F-MOT-MSETDYN X/2 Lower end point not repeatable
F-MOT-MOV X/32004: Message wait timeout
F-MOT-MSETDYN X/32004
F-HRDW-2
F-HRDW-3
In one instance I was able to re-initialize the motors and start running again. There was also an X/246 "light curtain triggered " error mixed in there. Does that indicate which side of the light curtain failed?
Daver5
by alphatronique on Sun Dec 15, 2013 7:12 pm
HI
based on my service manual and expeience
MOT-MSETDYN/2: lower end point not repeatable
End stop position not constant (checked during initialization).
• Mechanical problem.
• Check end stop hardware for loose screws etc.
HRDW-2: Hardware initiation failed
Failed to initialize motors.
• Hardware error. (Previous messages should give more information
about the source of the error).
This is in some cases normal system behavior. Always check previ-
ous messages for the cause of the error.
HRDW-3: Hardware not initiated
The application tried to move an axis or send some other message
before the hardware was initiated.
• Operator choose not to initiate the hardware.
• Software problem, unless this happens in combination with
messages that indicate that there is a hardware problem
somewhere in the system.
it have mechanical shock absorber that use as mechanical stop , at init machine hit this 3 time
and read back motor current for determine impact position (home) if the 3 mesire was to far away each other it trig that kind message
so make sure it have no obstruction and that damper was still good (have similar one at other end of X rail
also if you move that bumper you need to redo machine setup and calibration so if you never
start machine from HD clean install or do calibration make caution ..
it not hard to calibrate (specially since Tpsys 2.6 but still bit technical and need cal plate)
so try to change bumper was very last resort
P.S check also that the two 50 pin flat ribbon was not to tight and aluminium rain under it was set good it may misplaced and put to much tension when head was close to stopper and interfere whit it
Best regard
Marc Lalonde CID.
Alphatroniqe inc.
alphatronique
by Daver5 on Sun Dec 15, 2013 9:41 pm
Hi Marc,
Thank you. I appreciate you looking into those codes for me. I don't run the machine every day, but I do have a couple of jobs coming up this week. I will monitor and record any errors that I see to let you know.
Take care,
Daver5
by Daver5 on Sat Dec 28, 2013 6:50 pm
Hi Marc,
Could you lease take a moment top read through the following? I came into a bit of trouble yesterday that I wanted to ask you for any suggestions. After running a few boards my TP9-UFP machine hung up and asked me to press the emergency stop switch. It seemed that it hung over a feeder position with an 0805 resistor on the nozzle. In order for me to get out of this error I need to ALT F3 to get to the $ prompt, type "halt", shut down, and reboot machine. This is nothing new. However, when I tried to initialize the machine after reboot, the x axis would not move and initialization failed, with the F-MOT-MSETDYN X/32004 code listed. I removed the feeder banks from the machine, which then prompted a light curtain error, but repeated attempts to initialize failed, always with the same error, and with the machine initializing all axis' except X, which would never move at all. Each time, the light curtain cards would be showing a green status, but flash red for an instant. I also noticed that the MOT X card which under normal circumstances has a constant red led lit and a slow flashing green led, showed only the solid red. I went into the "EXIT to Service" menu and looked a the status of the MOT cards and saw that the X was not loaded. I then loaded it and rechecked the status, and it was loaded OK. At this time the MOT X could be seen in the solid red and slowly flashing green led's as normal. However, attempting to initialize the machine from this point led to no axis movement and an initialization failure. If I power down and reboot machine I end up back to the MOT X unloaded and all other axis initializing OK except for X. Any ideas? Is not loading during boot up typical of a MOT card failure? or could there be something in the light curtain safety circuit causing this? Any thoughts would be appreciated.
Daver5
by alphatronique on Sat Dec 28, 2013 11:57 pm
Hi Dave
ok that good question ...
if X not move during initializing it may look like a bad card or something electrical
what may suggest was ..
1-) move by hand X wagon to left side ,for this take grip on base plate ,never on camera or "C" unit for not move something and de-calibrate machine , main idea here was a-) check if bad encoder by move it position b-) reduce length of left side light fence
2-) check if possible on service menu for show transducer and see if value change during wagon move
3-) swap "X" mot card whit another one (mot-c or mot-Y) all that card was same and it load firm as need on it
if issue follow the card ,it card issue :mrgreen:
4-) for test light fence , carefully hear for relay sound and put hand on it both side of the head
if hear relay click when broke fence it work ...
normally when i got a motor time out i stay on menu and go "utility" then "re-init motor controller"
it may good idea to joint the yahoo group ,it small but some one else may got other solution to
Best regard
Best regard
Marc Lalonde CID.
Alphatroniqe inc.
alphatronique
by Daver5 on Sun Dec 29, 2013 1:04 pm
Hi Mark,
Thanks for the reply. I will check out those items, and will also try to register for your yahoo group as well. When changing MOT cards between axis, do I need to look for any jumper or dip switch settings on the cards, or are the x, y, and c completely interchangeable as used? Also, if I can get one from another machine, will it interchange as well, or are there differences?
Thanks again,
Daver5
by alphatronique on Sun Dec 29, 2013 2:02 pm
Hi
old MOT-1 need a setting change ... for X setting (see attached .pdf)
normally you may even swap a mot-1 for a newer mot-2 or even mot-3 card
and machine will configure it as it need ,it have make a great and good job on hardware design :mrgreen:
Best regard
Marc Lalonde CID.
Alphatroniqe inc.
alphatronique
by Daver5 on Sun Dec 29, 2013 5:45 pm
Hi Marc,
Thanks for the reply. Is there a trick to opening the PDF you mentioned? I don't see it anywhere.
Thanks again,
Daver5
by alphatronique on Mon Dec 30, 2013 12:08 am
ummm ok forum not seem to like .pdf ..
Best regard
Marc Lalonde CID.
Alphatroniqe inc.
alphatronique
