Teflon Etch Tank
Teflon Etch Tank
by mbodo on Fri Mar 22, 2013 7:26 pm
Not sure if this is the best forum group for this. Can teflon coated tanks be used for PCB etch with Ferric Chloride?
mbodo
Re: Teflon Etch Tank
by john444 on Fri Mar 22, 2013 11:54 pm
Hi Mbodo,
The teflon will be fine in ferric-chloride.
But, you cannot count on any coating to be perfect.
Any pin-hole or other imperfection will allow the ferric-chloride to penetrate.
If the base material is any of the vast majority of metals,
you will have corrosion under the teflon coating.
Don't use a teflon coated skillet with ferric-chloride!
It will ruin the skillet and the ferric-chloride will not be usable for etching copper.
Glass, silicone, polyethylene, polypropylene, PVC are the appropriate
materials for using & storing ferric-chloride.
Photography developing / processing trays are great because they have a
pouring spout in one corner.
Otherwise, almost any plastic or glass tray will do.
Good Luck, John
john444
by adafruit_support_mike on Sat Mar 23, 2013 1:26 am
As a side note, Teflon has been outrageously expensive for the past couple of years.
For this application, polyethylene (low density or high density) will do everything Teflon can at a fraction of the cost.
