DIY pick and place
DIY pick and place
by daniel_amesberger on Thu Jul 18, 2013 7:00 am
I thought I'll post some infos on a DIY pick and place machine I am building:
http://amesberger.wordpress.com/2013/07/18/diy-pick-and-place-machine/
Maybe someone finds the infos useful
Daniel
daniel_amesberger
Re: DIY pick and place
by adafruit_support_bill on Thu Jul 18, 2013 7:41 am
Wow! Nice project. Thanks for posting :D
by daniel_amesberger on Mon Jul 22, 2013 10:03 am
Here is a quick video testing 0603 placement with and without vision alignment:
http://www.youtube.com/watch?v=OTaeEG4P-E4
daniel_amesberger
by peter_ on Mon Jul 22, 2013 12:49 pm
that's beautiful work, thanks for sharing!
i'm also working on a pick and place -- can i ask what your 're using for your head machanism? they look like some kind of solenoid that allows vacuum suction, but you seem to have a pretty clever mechanism to allow the heads to change.
thanks!
peter_
by daniel_amesberger on Tue Jul 23, 2013 2:49 am
peter_ wrote:that's beautiful work, thanks for sharing!
thanks!
For the two heads I use two venturi vacuum generators combined with four compressed-air valves. They are on the back of the head so you can't see them in the video. Two of the valves switch on the vacuum, the other two generate a short pulse (15ms) to blow off the part. You can buy these valves completely integrated (venturi vacuum generator and two valves in one block).
For the nozzle changer I just glued a neodym magnet ring to the pickup nozzle. The SMD nozzles are clipped to a toolholder with simple fuse clips.
The rotation is done by a hollow shaft stepper motor. If you need more details I could post a close-up picture.
Daniel
daniel_amesberger
by peter_ on Tue Jul 23, 2013 12:53 pm
daniel_amesberger wrote:For the two heads I use two venturi vacuum generators combined with four compressed-air valves. They are on the back of the head so you can't see them in the video. Two of the valves switch on the vacuum, the other two generate a short pulse (15ms) to blow off the part. You can buy these valves completely integrated (venturi vacuum generator and two valves in one block).
If you'd be able to post more detailed pictures, that would be wonderful. If I can ask, what are the model numbers (and your preferred source) for the venturi vaccum generators and valves? Do you find that you need two to handle different sized parts (say an 0603 vs a TFQP-100), or are you hoping to use two for speed?
The magnet ring and fuse clips is very clever, and very low cost -- I like it!
thanks again,
Peter
peter_
