Adafruit OLED assembly question
by mhenstell on Tue Sep 24, 2013 5:26 pm
I'm working on a project that uses several OLED displays, similar to the 0.96" Adafruit display (http://www.adafruit.com/products/326). The display has an FCP connector with an odd 0.65mm pitch.
How does Adafruit assemble their units? It looks like the board is pasted, the OLED put down by hand, and I would guess the interface is hand-blasted with a rework gun. Am I wrong, can these OLEDs survive a trip through the toaster?
mhenstell
Re: Adafruit OLED assembly question
by alphatronique on Wed Sep 25, 2013 8:43 am
Hi
normally it solder by hotbar
it kind of bar the heat and activate glue on flex(carbon pad) or melt solder for tinned pad
but heat was localized on flex to PCB contact area ..
LCD will not survive to reflow oven
Best regard
Marc L.
hotbar soldering
Best regard
Marc Lalonde CID.
IPC Certified PCB Designer.
Alphatroniqe inc.
www.alphatronique.com
http://ca.groups.yahoo.com/group/MyData_Group
alphatronique
by mhenstell on Thu Sep 26, 2013 4:08 pm
Ah, ok. Thank you!
mhenstell
