Recomended multilayer PCB manufacturers
by siriusf on Sun Nov 09, 2014 8:47 pm
What multilayer PCB manufacturers do you recommend? It's too difficult to make your own multilayer pcb's?
siriusf
Re: Recomended multilayer PCB manufacturers
by adafruit_support_mike on Sat Nov 15, 2014 12:30 am
I get boards from Advanced Circuits: http://4pcb.com/
by sawyerh on Tue Sep 01, 2015 1:34 am
I like 4pcb, but I would also recommend checking out http://www.customcircuitboards.com/. I have been using both manufacturers with great results for multilayer PCB fabrication.
sawyerh
by wmdevices on Wed Sep 02, 2015 10:01 am
I've been using PCBCart.com for multilayer. They're quite good quality, good pricing. And they test boards. When I get panels from them, there are sometimes bad boards in an otherwise good panel, because they're properly tested.
I've done prototypes with them as well, and they're just as good. A little slow to get delivered though.
I'm testing PCBWay.com quality for multi-layer boards too. They'll do up to 6 layer. The 4-layer boards I've gotten have been good. Production quantity (100-200 boards for us) have been pretty good, but not as good as PCBCart, silk screen is blurrier. Their prototype service has been good (no shorts), but the mask has larger apertures (no mask between TSSOP for example) so they're more difficult to solder.
wmdevices
by MichaelJa on Mon Jan 18, 2016 10:09 pm
I just tried PCBway, they are pretty cheap and fast, and the boards are perfect! MODERATOR EDIT: LINK REMOVED
MichaelJa
by ansonit on Tue Apr 26, 2016 2:36 am
you can check my blog MODERATOR EDIT: LINK REMOVED ,i collect so many pcb manufacturer and other electrical forume
ansonit
