Extended Micro USB Receptacle??
by mushburger on Fri May 22, 2015 8:35 am
I have a project enclosure with walls that are about 3.7mm wide. I have an opening cut in one of the side walls for a micro USB receptacle. The problem is that the wall is just a little to thick to get a reliable connection from the male end of a USB cable.
Does anyone know of a part number for an extended USB female connector that could be mounted on my PCB? Or, does anyone know where I can get some USB cables with longer tips that can get through the thick enclosure walls?
mushburger
Re: Extended Micro USB Receptacle??
by Funman1 on Tue May 26, 2015 7:08 pm
I have used panel mount USB for the exact issue you describe, BUT then you have to wire it to the board instead of SMT
Funman1
by SDMI on Mon Jun 01, 2015 1:50 pm
Or you could use a small header and terminate the ends of the panel mounted usb jack with a crimp connector or similar.
SDMI
