๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
34-Pin FPC on 50-pin Adapter
by rshusko on Wed Jun 24, 2015 12:34 pm
Hey,
I have an OLED display with a 34 Pin .5 mm connection. It came with a FPC type connection that can be surface mounted. I was wondering if I can use this on the Adafruit 50 pin 0.5mm pitch FPC Adapter. I know that some of the pins won't be used but it seems to me that these would be isolated from the system. Also, is there any problems with soldering the board in place assuming I'm aligning the first pin.
Robert
rshusko
Re: 34-Pin FPC on 50-pin Adapter
by adafruit_support_mike on Wed Jun 24, 2015 2:00 pm
If you have a fine-pitch connector, the 50-pin adapter is just the tool for the job. You can use connectors with any number of pins.. the ones that don't get a connection just won't be part of your circuit.
If you want to solder a flat cable to a PCB, the multi-pitch adapter would be a slightly better choice: https://www.adafruit.com/products/1436 It's designed for that job.
