How do I strip FPC?
How do I strip FPC?
by Sailor1 on Sat Jul 04, 2015 8:22 pm
I need to strip some white FPC to solder it to one of the adapter boards. Is there a tool, or some method of doing this neatly?
Sailor1
Re: How do I strip FPC?
by adafruit_support_mike on Sun Jul 05, 2015 12:25 am
You can shave the insulation off with the blade from a craft knife. The trick is to lay it nearly flat so the edge skims across the surface of the metal without digging in.
Laying a ruler across the cable and using a few light strokes to make an initial groove in the insulation helps keep things even. Then you can set the edge of the blade in the groove, lean it over, and push.
by Sailor1 on Sun Jul 05, 2015 12:58 am
Hmmmm, ok, thanks. I had really been hoping there was a tool, because those conductors are so thin. Do you know how it is done industrially? i.e. thermal, purely mechanical, etc?
Sailor1
by adafruit_support_mike on Mon Jul 06, 2015 8:27 pm
I don't know of an industrial tool for stripping flex cable, but would imagine it's a more highly controlled version of a knife.
It's fairly easy to adjust a machine to a specific clearance, and when you're setting up an industrial tool you can run a lot of tests to be sure you've gotten exactly what you want. The production run will be for thousands of pieces, so a few dozen tests are cost-effective.
